TON mining
Is it possible to mine TON with HiveOS now? The Pools that are listed isn’t the new pool etchash.infinityton.com:4445 so is it still possible to mine TON with HiveOS? If so, can anyone explain how?
Ton isn’t mineable anymore. You can mine other coins and get paid in ton.
Ok so is it possible to mine in hiveos? Any guides on that?
You’d have to check on the pool website. It should give you the server to mine to and how to configure the address.
Alternatively you can just mine any other coin and trade it for ton on an exchange that offers both coins.
True but I’ll try mine so I get paid in ton. Thank you very much.
