I’m new to ETH mining, less than a month. I’ve started on windows but when I discovered HiveOs, imediatly changed my Rig OS
At this moment, Im using Asus Motherboard Z390-P and 6 GPUs as listed bellow.
I have some doubts that I would like to clarify, I am grateful if anyone can help. Even after hours of online research, some questions remain.
About RX 580 8G
So, as you can see I have 4 of them, two with Samsung memories and another two with Hynix. With these OC settings I’m at 30mh/s on each one.
All of them, have original Bios. Is there anyway to improve the Mh/s on these cards? I see some of these cards reaching 32-33 Mh/s on hive. Is there any tips to get to these numbers?
Even with same OC settings the Rx580 Powercolor Red Devil it’s hotter and with higher Watts.
About RX 5700 XT
Both of these GPUs have modded Bios.
The gygabite, it’s an Aorus with micron memory it’s stable at 940 Me clock, but memory it’s hot. It’s usually at 82-84 Cº is this number safe to run it 24/7?
The other 5700xt it’s a red devil with Samsung Memory. I’ve tried the same settings I was already using on my Aorus, but any value above 900 men clock, and it start to give invalid shares. On the other hand the memory on this one it’s much cooler.
Any hints on OC settings to these specific 5700xt?
One last question, as I stated above, my motherboard it’s an Asus Z390-P. Mathis motherboard, have two M.2 slots.
I’ve found online, some adaptors to convert these slots to PCI-E 4x 1x.
Does anyone know if these will work to connect a riser and expand the capacity of this motherboard to 8 GPUs? Will Hive Os recognize gpus connected this way?
Sorry for so many questions, I’m grateful if someone can help.
