my rig with 6 amd rx580’s will overheat during the day when it is hot, but runs great at night when it is cool. In windows I can run msi afterburner and set the max temperature, and it will slow the core clock down to maintain a maximum temperature. Can I do that with Hive OS?
This can be done through miner configuration - if miner supports it… Claymore does. Sgminer also has some fan control.
Thanks, after looking it up, I think -tt for fan control, and -ttli to limit the gpu should work.
