TeamRedMiner ethermine problem
When I’m trying to mine with TRM I’m getting this error: pool eu1.ethermine.org connection was closed by the pool.
I can mine normally with lolminer on ethermine. configs should be the same as on lolminer…
Have you mined with TRM before?
never
You need to make sure the SSL is unchecked. Dont know why, but i had the same thing happen when i switched from phx miner to trm.
Okay this worked. Thanks alot!
Glad to hear it Happy mining
