Hi to all,
I have bought a Biostar TB360 BTC pro 2.0 and cant seem to get the display to switch on.
I’m using the HDMI port so think it could be that?
I’m using a 9th gen intel core i5 1151 and 2x 8gb ddr4 2400 MHz
I’ve got a 850W PSU connect to aTX power 1 and 3
I’ve also got it connected to the two auxiliary slots which and 1 3080 connected into the same psu along with its riser
When the psu is switched on the lights on the GPU turn on and it sounds like I can hear the motherboard click on
What am I doing wrong ?
Connect HDMI on GPU and see if you have display on GPU. Keyboard Numlock works? If it works means PC is on but no display
Hi, I am facing the same issue, did you find any solution for it?
HI I am From Ecuador Latin America I have a Problem I duild a rig with 8 Gpu 2 rx6600 4 rx 6600xt and 2 rx 6700 xt it doesnt work what can i do ? please help
remove motherboard two 6pin that is output 12V
not input,
remove all gpu, enter bios, ensure csm disable and mining mode enable, and if you use AMD gpu, make sure all slot use Gen1
