My first rig with this mobo.
Unfortunately I can’t run any cpu miner. Rtm or xmr, I’ve tried every single miners.
Hiveos stop the process and reboot.
I don’t know what to do…
update your hive to start, youre on an old version/driver.
dont use etheminer either, its outdated and unsupported. better to use lolminer(lowest dev fee), trex or gminer etc.
Thank you for the prompt reply.
During the screenshot I was trying many miners combinations.
Same problem right now with latest drivers.
Lolminer + nanominer (used here on others)
Then the rig goes offline.
is your cpu going to 90+?
Temp? No
how high is it getting? if its at 72 when the cpu just boots i cant imagine its much lower.
use xmrig new
open the miner in the shell, see what it says
type miner
, then press ctrl a+a to switch from lolminer to xmrig
make sure your server/wallet addresses are correct.
Same pool/wallet for every rig. The only one who doesn’t work
Same problem with supportxmr pool or raptoreum
