How do I activate low power mode for T-rex for ETH?
"lhr_low_power" : 1
Add that to your flight sheet in Extra config arguments
Thank you.
Do you know if this is still maintained in the last version?
I would like to increase the efficiency over the profits but my cards go from 75 LHR to 66. Is there any way to keep them in 68/69?
Know that it would be difficult to keep both worlds, but would like to understand how to optimize it.
Thanks in advance,
It should still be an option in the latest t-rex. You should be able to add "lhr-tune":"68" to your config if you wanted to force it to a lower LHR unlock.
I currently have been using NBMiner 40.1 with "lhr-mode":"2" and getting better results for low power consumption. lhr-mode 2 tries to unlock the LHR at 71 and use less power.
