Hello I have used the T-REX 25.12 with two rigs of 6x3060 12 gb lhr and it keep crushing all the time i was using drivers 460.39 and same thing happens with the newest drivers. When i get back to previous version of T rex it started to work normally.
Does anyone had similar problem?
Try with lolMiner 1.48 to get the unlock +85%… using Lock Core to 1500 you will not have problems.
Memories very low in that rig… with 2000 - 2200 easy the +41Mhs and full stability
what clocks?
last two kards are problematic ones one is giving to much bad shares when clock it and other goes ower 80degrees, i have change pads two times and pasta last i hawe used thermal grizly , no help.
LoL miner has qute improved since last time I used it, thanks for bringig it to my atention.
Here is my situation with 12x 3060 with lol miner on flexpool:
B.R.
need to use locked core clocks with latest drivers for best results.
