I have Gigabyte GA H110 D3A motherboard and 3x sapphire RX 580 nitro+ 4GB GPUs. I flashed Hive on USB drive and can’t start the system. I have working keyboard up until this point:http://forum.hiveos.farm/uploads/editor/92/4mylzvnhtksj.png
After that screen I just get blinking cursor, keyboard is not responding and system isn’t loading.
I plugged monitor into motherboard, because my GPUs don’t have VGA port.
Is there a way to load the system without connecting monitor to the GPU?
If it’s necessary to connect monitor to GPU can that GPU be connected to x16 port using riser?
I just don’t want to disassemble the system because I cannot plug GPU directly into x16 slot. Also my monitor uses VGA connector so I would have to buy VGA to DVI cable.
P.S. you can answer in English or Russian, I understand both languages.
