my system is very unstable. Sometimes it starts normal, sometimes it shows this printing problem. Can someone help me? I do not know what to do. i use 2 gtx 1660s, 01 rx 580 and 05 rx 470. im using nbminer now, but i already tried another miners like phoenixminer, teamredminer for amds and t rex nvidia. and sometimes one of the rx 470 cards is not recognized for the sistem.
Same here. I am using 1660s and 2070s.
Every now and then the NBMiner crashes. Other miners such as Phoenix, T-rex, Gminer, Bminer are all good.
Did anyone get this resolved? I’m running into this exact issue.
I’m getting the same error on a single 3060 system
Miner was hashing fine until I lost power. Tried soft and hard reboot, miner stop-restart etc…still shows this error
I encountered the same issue with biostar TB360-PTC PRO. ok with 1 card, 2 or more it will start crashing with code 11. anyone else have this issue and resolved?
Thanks!
Same error here! has anyone solved this problem or is it just a case of ditching NBminer?
I got this error when i start mining. If i put 14 GPU i dont have any problems, but if i put the 15th, i got the error and it restarts, got the error it restars, etc. etc. Sometimes it boots and starts mining with no problems for hours, but if i have to restart the system or it restars for any problems, its hard to boot it again.
MOBO Asus Prime Z-490P.
Processor Intel Celeron G5905
Same problem here. 5x AMD 6600xt, 3x 6600. Sometimes boots OK and mines with 1 card lower HR, sometimes doesn’t boot. NBUminer.
