Hi, I have 1 worker(2 amd cards) with hiveos mining at nanopool. When I want to switch to hiveon pool in flieght plan, the miner dont start and after reboot its mines again to nanopool.
How can I switch and add more miner with hiveos?
Hive OS can more than you can imagine
Something wrong with your settings - please show it
Sometimes it is better to create a new flight sheet & use the rocket to activate it…when you select new pool remember to select server, closest to you…
Ok, I will delete everything and start direkt with hiveon pool.
It’s depends your platform
AMD:
- TeamRedMiner
Nvidia
- T-Rex
Mix / Universal
- lolMiner
- Gminer
- NBminer
THX, now it works with TeamRedMiner
