I’m not sure what is causing this. All of a sudden half the power will be lost and a reboot will immediately fix the issue. Is this an unstable overclock?
I have 6 GPUs:
2 3090s
2 6800 XTs
1 2070
1 6600 XT
Everything was fine until I added the second 3090 but I reconfigured them so each power supply is only doing one, so power shouldn’t be an issue. Each of them are capped at 300W.
Is the nvidia/AMD mix making it unstable?
It usually will run at a steady 430-450MH/s for 3-5 hours and then reboot itself (I have watchdog turned on)
