How long does it take to see profitability in mining hiveos “YOUR FUNDS” does not change,
thats your account funds balance, not your wallet. thats where youll see funds from referrals go.
The money goes straight to the wallet?
What are the numbers in green?
How long does the money go through?
the coin you are mining will get paid out to your wallet by the pool you’re using once you meet the threshold of that pool. check your pools payout policy for more info. the numbers in green are your account balance (like i said funds from referrals will go here)
I see now my pool policy is a minimum of 0.1 ETH
By the time I get to the quota I’m supposed to see something in the data here?
no, that section is your account balance, unless you add funds or get referrals that will stay at 0, you are mining eth presumably, you will be paid in eth, not USD.
You only care about the green “Your funds” amount if you are using the paid for features of Hive OS or if you exceed the 1 Free Worker, +3 Free on Hiveon Pool counts.
