The problem is shown below:
ETH: 1 pool is specified
Main Ethereum pool is eth-eu1.nanopool.org:9999
At least 16 GB of Virtual Memory is required for multi-GPU systems
Make sure you defined GPU_MAX_ALLOC_PERCENT 100
Be careful with overclocking, use default clocks for first tests
Press “s” for current statistics, “0”…“9” to turn on/off cards, “r” to reload pools, “e” or “d” to select current pool
OpenCL initializing…
AMD Cards available: 6
GPU #0: Tahiti (AMD Radeon HD 7900 Series), 2730 MB available, 16 compute units (pci bus 1:0:0)
GPU #1: Tahiti (AMD Radeon HD 7900 Series), 2953 MB available, 16 compute units (pci bus 2:0:0)
GPU #2: Tahiti (AMD Radeon HD 7900 Series), 2953 MB available, 16 compute units (pci bus 3:0:0)
GPU #3: Tahiti (AMD Radeon HD 7900 Series), 2953 MB available, 16 compute units (pci bus 8:0:0)
GPU #4: Tahiti (AMD Radeon HD 7900 Series), 2953 MB available, 16 compute units (pci bus 11:0:0)
GPU #5: Tahiti (AMD Radeon HD 7900 Series), 2953 MB available, 16 compute units (pci bus 12:0:0)
POOL/SOLO version
Cannot build OpenCL program for GPU 0
Cannot build OpenCL program for GPU 1
Cannot build OpenCL program for GPU 2
Cannot build OpenCL program for GPU 3
Cannot build OpenCL program for GPU 4
Cannot build OpenCL program for GPU 5
/hive/bin/claymore: line 137: 29775 Segmentation fault      ./ethdcrminer64
claymore exited, waiting to cooldown a bit
soooooo what hapened ?
