Here is the detailed log:
[20:37:18] Set default algorithm to neoscrypt
[2018-08-26 20:37:18] Log date is now 2018-08-26
[2018-08-26 20:37:18] Global quota greatest common denominator set to 1
[2018-08-26 20:37:18] Started sgminer 5.5.6-gm
[2018-08-26 20:37:18] * using Jansson 2.7
[2018-08-26 20:37:18] Loaded configuration file sgminer.conf
[2018-08-26 20:37:18] CL Platform vendor: Advanced Micro Devices, Inc.
[2018-08-26 20:37:18] CL Platform name: AMD Accelerated Parallel Processing
[2018-08-26 20:37:18] CL Platform version: OpenCL 2.1 AMD-APP (2527.3)
[2018-08-26 20:37:18] Platform devices: 6
[2018-08-26 20:37:18] 0 Ellesmere
[2018-08-26 20:37:18] GPU0: detected PCIe topology 0000:01:00.0
[2018-08-26 20:37:18] 1 Ellesmere
[2018-08-26 20:37:18] GPU1: detected PCIe topology 0000:02:00.0
[2018-08-26 20:37:18] 2 Ellesmere
[2018-08-26 20:37:18] GPU2: detected PCIe topology 0000:03:00.0
[2018-08-26 20:37:18] 3 Ellesmere
[2018-08-26 20:37:18] GPU3: detected PCIe topology 0000:04:00.0
[2018-08-26 20:37:18] 4 Ellesmere
[2018-08-26 20:37:18] GPU4: detected PCIe topology 0000:05:00.0
[2018-08-26 20:37:18] 5 Ellesmere
[2018-08-26 20:37:18] GPU5: detected PCIe topology 0000:07:00.0
[2018-08-26 20:37:18] Default Devices = all
[2018-08-26 20:37:18] set_devices(all)
[2018-08-26 20:37:18] Loading settings from default_profile for pool 0
[2018-08-26 20:37:18] Pool 0 Algorithm set to "neoscrypt"
[2018-08-26 20:37:18] Pool 0 devices set to "all"
[2018-08-26 20:37:18] Pool 0 lookup gap set to "(null)"
[2018-08-26 20:37:18] Pool 0 Intensity set to "8"
[2018-08-26 20:37:18] Pool 0 Thread Concurrency set to "(null)"
[2018-08-26 20:37:18] Pool 0 GPU Clock set to "(null)"
[2018-08-26 20:37:18] Pool 0 GPU Memory clock set to "(null)"
[2018-08-26 20:37:18] Pool 0 GPU Threads set to "(null)"
[2018-08-26 20:37:18] Pool 0 GPU Fan set to "(null)"
[2018-08-26 20:37:18] Pool 0 GPU Powertune set to "(null)"
[2018-08-26 20:37:18] Pool 0 GPU Vddc set to "(null)"
[2018-08-26 20:37:18] Pool 0 Shaders set to "(null)"
[2018-08-26 20:37:18] Pool 0 Worksize set to "(null)"
[2018-08-26 20:37:18] Trying to set current pool...
[2018-08-26 20:37:18] Probing for an alive pool
[2018-08-26 20:37:18] Testing neoscrypt.eu1.unimining.net
[2018-08-26 20:37:18] Succeeded delayed connect
[2018-08-26 20:37:18] neoscrypt.eu1.unimining.net stratum session id: 0deaf5af1a5375d238a5d16a3c037583
[2018-08-26 20:37:18] Stratum authorisation success for neoscrypt.eu1.unimining.net
[2018-08-26 20:37:18] neoscrypt.eu1.unimining.net alive
[2018-08-26 20:37:18] Startup GPU initialization... Using settings from pool neoscrypt.eu1.unimining.net.
[2018-08-26 20:37:18] Startup Pool No = 0
[2018-08-26 20:37:18] compare_pool_settings()
[2018-08-26 20:37:18] Switching to intensity: pool = 8, default =
[2018-08-26 20:37:18] intensity -> 8
[2018-08-26 20:37:18] GPU 0 Thread Concurrency set to 0.
[2018-08-26 20:37:18] GPU 1 Thread Concurrency set to 0.
[2018-08-26 20:37:18] GPU 2 Thread Concurrency set to 0.
[2018-08-26 20:37:18] GPU 3 Thread Concurrency set to 0.
[2018-08-26 20:37:18] GPU 4 Thread Concurrency set to 0.
[2018-08-26 20:37:18] GPU 5 Thread Concurrency set to 0.
[2018-08-26 20:37:18] Set GPU 0 to neoscrypt
[2018-08-26 20:37:18] Set GPU 1 to neoscrypt
[2018-08-26 20:37:18] Set GPU 2 to neoscrypt
[2018-08-26 20:37:18] Set GPU 3 to neoscrypt
[2018-08-26 20:37:18] Set GPU 4 to neoscrypt
[2018-08-26 20:37:18] Set GPU 5 to neoscrypt
[2018-08-26 20:37:18] Allocate new threads...
[2018-08-26 20:37:18] Assign threads for device 0
[2018-08-26 20:37:18] Thread 0 set pool = 0 (neoscrypt.eu1.unimining.net)
[2018-08-26 20:37:18] Init GPU thread 0 GPU 0 virtual GPU 0
[2018-08-26 20:37:18] List of devices:
[2018-08-26 20:37:18] Selected 0: Ellesmere
[2018-08-26 20:37:19] Preferred vector width reported 1
[2018-08-26 20:37:19] Max work group size reported 256
[2018-08-26 20:37:19] Maximum work size for this GPU (0) is 256.
[2018-08-26 20:37:19] Your GPU (#0) has 36 compute units, and all AMD cards in the 7 series or newer (GCN cards) have 64 shaders per compute unit - this means it has 2304 shaders.
[2018-08-26 20:37:19] Max mem alloc size is 4244635648
[2018-08-26 20:37:19] Using source file neoscrypt.cl
[2018-08-26 20:37:19] GPU 0: selecting lookup gap of 2
[2018-08-26 20:37:19] GPU 0: computing max. global thread count to 256
[2018-08-26 20:37:19] Setting worksize to 256
[2018-08-26 20:37:19] Using binary file neoscryptEllesmeregw256l8lgtc256.bin
[2018-08-26 20:37:19] No binary found, generating from source
[2018-08-26 20:37:19] Building binary neoscryptEllesmeregw256l8lgtc256.bin
[2018-08-26 20:37:19] Trying to open /usr/local/bin/neoscrypt.cl...
[2018-08-26 20:37:19] Trying to open ./gm/neoscrypt.cl...
[2018-08-26 20:37:19] Trying to open ./gm/kernel/neoscrypt.cl...
[2018-08-26 20:37:19] Using ./gm/kernel/neoscrypt.cl
[2018-08-26 20:37:19] CompilerOptions: -I "./gm" -I "./gm/kernel" -I "." -D WORKSIZE=256 -I "/usr/local/bin" -D LOOKUP_GAP=2 -D MAX_GLOBAL_THREADS=256
[2018-08-26 20:37:19] stratum_rthread: parsing {"id":null,"method":"mining.set_difficulty","params":[128]}...
[2018-08-26 20:37:19] We made it to parse_method()!
[2018-08-26 20:37:19] neoscrypt.eu1.unimining.net difficulty changed to 128
[2018-08-26 20:37:19] stratum_rthread: parsing {"id":null,"method":"mining.notify","params":["f1","1aef85084f16d80c2cd61aadcd1981f4ba609f8f2b9af04c03b47c6900000000","010000000100000000000000000000000000000000000
00000000000000000000000000000ffffffff1803cc9e020434e5825b08","7969696d70000000000002efc04025000000001976a9144d90b9c375d68411760d6466ca5fd659a25ac21788acd342c26f000000001976a914329812b10de2c9831fc6766b5b09dc3627e
6969888ac00000000",["ae4b4c72c9fa194535535b56d423f8a5bd31347790a8abba0f607960e902f8d4","d0c2f9fb8d89c7b02c63098383f4f67e9ef27c614a97508b1e92fa474f87f097"],"20000000","1c12f35d","5b82e534",true]}...
[2018-08-26 20:37:19] [THR0] gen_stratum_work() - algorithm = neoscrypt
[2018-08-26 20:37:19] [THR0] Generated stratum merkle 537dd206a234fa8f12d9383ae7f22ced04253ec05a305ad7a2681d0603e23cbf
[2018-08-26 20:37:19] [THR0] Generated stratum header 000000200885ef1a0cd8164fad1ad62cf48119cd8f9f60ba4cf09a2b697cb40300000000537dd206a234fa8f12d9383ae7f22ced04253ec05a305ad7a2681d0603e23cbf34e5825b5df3121c00000
000000000800000000000000000000000000000000000000000000000000000000000000000000000000000000080020000
[2018-08-26 20:37:19] [THR0] Work job_id f1 nonce2 0 ntime 5b82e534
[2018-08-26 20:37:19] [THR0] Generated neoscrypt target 0x000001fffe000000000000000000000000000000000000000000000000000000
[2018-08-26 20:37:19] New block: 00000000697cb4034cf09a2b8f9f60baf48119cdad1ad62c0cd8164f0885ef1a... diff 1.16T
