Settings for Samsung RTX 3060 TI LHR
I have 6 RTX 3060 TI LHR, 5 of them are Hynix memory and one is samsung. I’m dual mining ETH/ERG on Hynix, but i can’t make the samsung do dual mining. It goes to LHR mode. Any advice for that problem ?
when dual mining, tune the card on the second algo alone, in your case, ergo/autolykos2. once you find the best settings to keep lhr from engaging on ergo, only then switch to the dual mining flight sheet.
Okey, i’ll try it ! Thanks mate !
We’re you able to get that samsung card to dual mine?
I have a rig with 7x 3060 ti LHRs. All with Samsung memories. Never got them to work on dual mining. Same issue. Keeps detecting lhr lock.
