Hi, Can someone guide me to correct setting for EVGA 3080 FTW3 Ultra ? I’m starting with only 1 x 3080 for now.
Need the memory clock, voltage & wattage setting. Many thanks
What Algorithm?
I have 2 FTw3 3080s
Hi ! I plan on mining Ethereum to start with. I understand it’s the most profitable one currently.
You have to check whattomine.com and see which is more profitable.
I’ve been mining Ergo for nearly a week its been more profitable for me, by a abiut 4$
3080 ethereum
1070 absolute core clock
2150 mem
230 pl
You should get 99Mh
Many thanks. I will check that. Also, do you change the GPU OC settings as per the algorithm that we want to mine ?
And do you have any recommendation for the wallet and exchange ? I’m currently looking at Exodus as the wallet. Still researching on the exchange part.
I yes. Different algorithms require different ocs.
And yes, I use exodus and coinbase. Gate.io for Ergo.
Tried the settings you propose but unfortunately I get DAG crashing due to overclock settings. Can you advise which BIOS you are running on the FTW3 Ultra and if the bios switch is to the left or to the right as you are looking at the fans of the card?
Put a 45 second delay on the overclocks.
Didnt like it, DAG crashed immediately.
What miner u using?
Gminer as I am using multiple types of cards
Does it run with no over clocks?
yes it does and it does with the ones above - that is the best performance I can achieve as it will lower hashrate if I increase either core or mem speed. Max mem speed before it crashes is 1600
Thats odd for a ftw3. Im not sure
