SERO Flight Sheets for https://pool.sero.cash
Please tell me how to set up miner config according to the pool:
T-Rex.exe -a ProgPOW - COOIN SERO -O STRATUM + TCP: //pool2.sero.cash: 8808 -U адрес --P X -W worker
Haven’t used it in a while, but this used to be my setup
t-rex N
Url stratum+tcp://pool2.sero.cash:8808 stratum+tcp://pool4.sero.cash:8808
Algo progpow
Pass x
Worker %WORKER_NAME%
Template %WAL%
User Config "coin": "sero" "lhr-tune": "-1"
Thank you very much. Everything worked ))
Thanks, this helped me as well.
I cant mine with my AMD cards , Trex and nvidia totaly fine but AMDs not
i try Srbminer, ethminer, NBminer 39.5 all but it not works at all, with nbminer job found but share at all, with SRBminer i have invalid login
but in windows every thing is fine with SRBminer, i dont know why!!!
if anyone can help i preciated
