**SERIOUS** SK hynix VRAM on the RTX 3060 ti is terrible
That is a my result stable for now.
NBMiner v39.2
This is the highest stable I can get with Hynix.
nbminer 39.2 / Hive: 0.6-210@210915
LHR cards Gainward
Its what i get more or less, like 40mh.
Thats not bad at all
You PM me, I guide you to run on 28Mh with 3060 Ti Hynix card
Any recommended overclock for hynix
I have Hynix 3060ti on eth, it is so bad…
Anyone can get 60mh ? pls share the setting
Alright.
I have 9 of those shitty 3060ti lhr Hynix and touching the OC make them crash real bad.
After doing extensive research. Hynix meme works best with a lower mem.
You will be able to hit 55mh/s on CFX > but def not 60. Sorry.
A few settings that works depending on the quality of your card.
Best one and stable one :
54-55mh
Core 1400
Mem : 1700
Wats : 170 (adjust 160-175 depending on cards)
52mh but much much more stable
SAFEST setting
54-55mh
Core 1400
Mem : 1500
Wats : 165
anything pass 1700 crashes over time. your LA just can’t take it.
Good luck miners (like this comment so other can see the answer)
I added one of these cards to my rig and it keeps the rig from loading like half the time, i think i’m just going to trade this for another 3060 ti
This GPUs are terrible, the worst i ever had, anyway after hours and hours of overclock settings i found a stable combination to have 40/41mhs mining ETH
DRIVERS: 470.74
MINER: nbminer (last version)
CORE: -550
MEM: 1800
PL: 130
If you find anything better, post it!
Eu estou usando:
1 3060 on Trex
2 3060 on Gminer
Waiting to check shares and stability
I am using:
does this work for ergo on nanominer? i’m having trouble with samsung memory for now.
Try this setting core: -625 mem: 2500 pl: 110.
I got 130 on my 3060 ti with samsung memory
Thank you… I finally got it too… was struggling with 32mhs for the longest time.
Hi Dusty,
do you have any extra settings in miner?
i have nvidia with hynix and i am not getting anything near yours with same settings.
What GPU do you have?
ichill x3 red
RTX3060Ti?
yes
here is a screenshot
did you update the dtivers?
Anyway every VGA is different, mine is an MSI, you should keep trying with diferent settings.
