Seeking Technical Tips for Optimizing My Hiveon Experience
Hello Hiveon community!
I am new to Hiveon, and I’m eager to optimize my mining setup. I’m looking for technical advice and suggestions from seasoned users.
Here are a few specific areas I’m interested in:
  1. Optimal Configuration: What are the best settings for maximizing hash rates while maintaining system stability? Any specific configurations that you recommend?
  2. Monitoring Tools: Are there any essential monitoring tools or metrics you use to track performance and ensure everything runs smoothly?
  3. Troubleshooting: What common issues should I be aware of, and how can I effectively troubleshoot them?
  4. Software Integration: Any tips on integrating Hiveon with other mining software or tools for better efficiency?
When I was Googling about it, I came across these resources Hiveon ASIC Firmware - Optimizing Your Mining Operations Qlik Sense Tutorial however, they are quite informative but I wanted to learn from community members of Hiveon.
I appreciate any insights or experiences you can share. :slightly_smiling_face:
Best Regards
Can you tell me a little bit about your mining setup? More information the better, but things like motherboard, cpu, gpu, fpga, asic, electricity costs, amount of machines, ambient temperatures, cooling/airflow situation of your site and so on. The answers will vary based on what hardware you have and what your plan or goals are.
