Security problem
Title: NVIDIA 580 Legacy driver installation fails – GTX 1060 + 3× P106-100
Hi everyone,
I’m trying to update my NVIDIA driver from version 550.142 (CUDA 12.4) to 580.178.04 Legacy on HiveOS.
My GPU setup:
  • 1× NVIDIA GTX 1060 6GB
  • 3× NVIDIA P106-100 6GB
All four GPUs are detected correctly by HiveOS and work with driver 550.142.
However, when I run:
nvidia-driver-update 580 --legacy
the installation fails with the following output:
Loading drivers list - 22
Latest driver for 580 series - 580.178.04
Installed version - 550.142 (CUDA 12.4)
WARNING: a GPU is not visible to the running driver
Driver package already exists
Checking package integrity
check sums and md5 sums are ok
Stopping services
Unload modules failed (nvidia)
Starting services
Driver installation failed (1)
I discovered that the CLORE.AI hosting service was running in the background and using all four GPUs.
I stopped and disabled the service and removed its installation. However, the Python process became stuck in an uninterruptible sleep state (STAT Xs), and the NVIDIA driver could not be unloaded.
The Clore service is no longer needed.
My questions:
  1. How can I successfully install the NVIDIA 580 Legacy driver?
  2. Is a HiveOS reboot sufficient to clear the stuck Python process?
  3. Is there a recommended way to update the driver without reinstalling HiveOS?
  4. Are there any known compatibility issues with GTX 1060 and P106-100 GPUs on driver 580?
Thanks for your help!
