First, thank you for looking at this. Any and all help is much appreciated.
Here is a quick rundown of the machine.
I have a schedule where it just changes the mining pool.
For now, I have it swapping every hour to help find a solution to the issue.
00:00 to 01:00 - hiveon
01:00 to 02:00 - 2miners
02:00 to 03:00 - hiveon
03:00 to 04:00 - 2miners
and so on.
I have used every miner and it still fails.
I also get GPU driver error, no temps, and all GPU’s show temps.
I noticed after I make a flightsheet change I get high LA
The WatchDog is also not successful in rebooting the system when this happens.
Update 1: It looks like the crash is happening due to the over\under clocks. I am able to swap between the flightsheets without issue when all clocks are removed.
Update 2: This is tied to the 2060 Super OC. If the 2060 has no OC. The swap between schedules works fine. Willl update soon. Going to run more tests
