Sapphire RX 5600 XT (Micron) - not moded
any one has a best setting for the RX 5600 xt sapphire with the exact chip? , couldn’t go higher , if I do it crashes , I’m using phoenix miner
please help !
what are you raising to go higher? try memory 900 or 920.
If I put 890 it crashes
try raising a bit the core voltage to 820 and then try higher memory.
Mobo,
I can help you if you want. for Sapphire RX5600XT i have 43.5-44 Mh/s Stable
Contact me to Telegram.
What is your tel id ?
its @kenshinji59
Anyone able to point me on how to get that 41-43 stable hasrate?
I did with modded bios helped and provided by [Kenshinji]
Hi MoboFarm and Kenshinji, can you share the modded bios? Trying to achieve a better MH with Sapphire 5600XT / Micron and i’m stuck at 37MH unstable. TX.
Contact me on telegram : @rex1lll
