i dont understand your question about this card…
every card is different…and has different settings …
do research and find the best results on your own…
Thank you so much for your reply.
According to your description above, I configured my card. According to the specifications, is this the best config for my card?
And is the temperature of 72 degrees for mem temp normal?
Speed your fan up to 60 - 70 % to help the temps (remove the autofan) … If you are stable for over 2 ,3 days you are ok to downclock litle by litle your core and voltage to cut off temps and wattage…(if it is not stable return to this values)…
Happy mining!!!
hi, I had the same problem with the same 2 cards and it was solved thanks to the adjustments that @nanial gave, I added SoC VDDmax mV to 850 so the power dropped to 110 watts and 107 watts respectively, I keep making small adjustments in MEM freq to optimize HASHRATE , power problem is gone.
Great job…
Happy new Year and happy mining!!!
