S19pro固件会多两个未知矿工切走算力
Those are for the developer fee, they are low difficulty pools so lots of small fast shares to minimize any impact on your pools hashrate
但是机器启动很慢,池算力不足
Are you mining to a local node? have you tried using a pool? What kind of hashrate are you seeing locally? And what hashrate are you seeing on the pool?
S19s can take a few minutes to start if it’s in a cool area. That’s normal
有用池的,但是池的比例一样失调,机器显示136t/s池接受最低时80t/s
Any rejects or invalids? Have you tried other pools?
没有拒绝,现在是f2pool
Just to confirm, the pool hashrate is only showing 80TH and your miner is showing 136TH?
Yes.但是情况在重启后发生变化,自动调和结束后,手动重启算力会增加
