Hi, im triying to run on a sd card the new firmware of hiveos in my s19, i downloaded the xilinx 19 image and the s19 boot perfect, but the kernell log shows me ERROR POWER LOST.
i need help. Thank You!
have you tried reinstalling? at what point does it show that in the kernel log?
hi i show you the log
[ 0.000000] Kernel command line: mem=240M console=ttyPS0,115200 ramdisk_size=33554432 root=/dev/ram rw earlyprintk
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 196300K/245760K available (6317K kernel code, 243K rwdata, 1932K rodata, 1024K init, 232K bss, 33076K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xcf800000 - 0xff800000 ( 768 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xcf000000 ( 240 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc090e410 (9242 kB)
[ 0.000000] .init : 0xc0a00000 - 0xc0b00000 (1024 kB)
[ 0.000000] .data : 0xc0b00000 - 0xc0b3cda0 ( 244 kB)
[ 0.000000] .bss : 0xc0b3cda0 - 0xc0b77024 ( 233 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] efuse mapped to cf800000
[ 0.000000] ps7-slcr mapped to cf802000
[ 0.000000] L2C: platform modifies aux control register: 0x72360000 → 0x72760000
[ 0.000000] L2C: DT/platform modifies aux control register: 0x72360000 → 0x72760000
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
[ 0.000000] zynq_clock_init: clkc starts at cf802100
[ 0.000000] Zynq clock init
[ 0.000010] sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
[ 0.000028] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
[ 0.000051] Switching to timer-based delay loop, resolution 3ns
[ 0.000290] clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
[ 0.000315] ps7-ttc #0 at cf80a000, irq=18
[ 0.000614] Console: colour dummy device 80x30
[ 0.000629] Calibrating delay loop (skipped), value calculated using timer frequency… 666.66 BogoMIPS (lpj=3333333)
[ 0.000642] pid_max: default: 32768 minimum: 301
[ 0.000777] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000786] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001394] CPU: Testing write buffer coherency: ok
[ 0.001596] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001656] Setting up static identity map for 0x100000 - 0x100058
[ 0.100278] CPU1: failed to boot: -1
[ 0.100310] Brought up 1 CPUs
[ 0.100319] SMP: Total of 1 processors activated (666.66 BogoMIPS).
[ 0.100325] CPU: All CPU(s) started in SVC mode.
[ 0.101103] devtmpfs: initialized
[ 0.103363] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.103780] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.104742] pinctrl core: initialized pinctrl subsystem
[ 0.105876] NET: Registered protocol family 16
[ 0.107708] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.150230] cpuidle: using governor menu
[ 0.159403] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.159414] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.159560] zynq-ocm f800c000.ps7-ocmc: ZYNQ OCM pool: 256 KiB @ 0xcf880000
[ 0.211364] vgaarb: loaded
[ 0.211702] SCSI subsystem initialized
[ 0.211985] usbcore: registered new interface driver usbfs
[ 0.212053] usbcore: registered new interface driver hub
[ 0.212488] usbcore: registered new device driver usb
[ 0.213006] media: Linux media interface: v0.10
[ 0.213118] Linux video capture interface: v2.00
[ 0.213281] pps_core: LinuxPPS API ver. 1 registered
[ 0.213289] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.213369] PTP clock support registered
[ 0.213537] EDAC MC: Ver: 3.0.0
[ 0.220613] Advanced Linux Sound Architecture Driver Initialized.
[ 0.230630] clocksource: Switched to clocksource arm_global_timer
[ 0.249422] NET: Registered protocol family 2
[ 0.250425] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.250461] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.250504] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.250552] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.250772] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.250978] NET: Registered protocol family 1
[ 0.261308] RPC: Registered named UNIX socket transport module.
[ 0.261316] RPC: Registered udp transport module.
[ 0.261321] RPC: Registered tcp transport module.
[ 0.261326] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.261353] PCI: CLS 0 bytes, default 64
[ 0.261571] Trying to unpack rootfs image as initramfs…
[ 0.262162] rootfs image is not initramfs (no cpio magic); looks like an initrd
[ 0.393187] Freeing initrd memory: 20004K (cc770000 - cdaf9000)
[ 0.393584] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.395352] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.407041] workingset: timestamp_bits=28 max_order=16 bucket_order=0
[ 0.417880] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.418961] io scheduler noop registered
[ 0.418976] io scheduler deadline registered
[ 0.419004] io scheduler cfq registered (default)
[ 0.420977] dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-241330
[ 0.420992] dma-pl330 f8003000.ps7-dma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
[ 0.421946] e0000000.serial: ttyPS0 at MMIO 0xe0000000 (irq = 159, base_baud = 6249999) is a xuartps
[ 0.924395] console [ttyPS0] enabled
[ 0.927264] xdevcfg f8007000.ps7-dev-cfg: ioremap 0xf8007000 to cf86e000
[ 0.933439] [drm] Initialized drm 1.1.0 20060810
[ 1.110764] brd: module loaded
[ 1.199664] loop: module loaded
[ 1.206446] CAN device driver interface
[ 1.210690] gpiod_set_value: invalid GPIO
[ 1.214328] libphy: MACB_mii_bus: probed
[ 1.290710] macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 31 (00:0a:35:00:00:00)
[ 1.299154] Generic PHY e000b000.etherne:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=e000b000.etherne:00, irq=-1)
[ 1.309463] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.314004] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.319833] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.325442] ehci-pci: EHCI PCI platform driver
[ 1.328747] usbcore: registered new interface driver usb-storage
[ 1.335268] mousedev: PS/2 mouse device common for all mice
[ 1.350627] i2c /dev entries driver
[ 1.353463] cdns-i2c e0005000.ps7_i2c: 100 kHz mmio e0005000 irq 154
[ 1.361431] Xilinx Zynq CpuIdle Driver started
[ 1.365682] sdhci: Secure Digital Host Controller Interface driver
[ 1.370470] sdhci: Copyright(c) Pierre Ossman
[ 1.373629] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.410785] mmc0: SDHCI controller on e0100000.ps7-sdio [e0100000.ps7-sdio] using ADMA
[ 1.424946] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.432296] usbcore: registered new interface driver usbhid
[ 1.438553] usbhid: USB HID core driver
[ 1.449573] nand: disable subpage write
[ 1.452187] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 1.457181] nand: Micron MT29F2G08ABAEAWP
[ 1.459866] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.466132] nand: NAND_ECC_HW
[ 1.467737] nand: NAND_ECC_HW_SYNDROME
[ 1.470170] mtd->writesize = 2048
[ 1.472252] ecc->strength = 1
[ 1.473852] ecc->size = 2048
[ 1.475411] mtd->writesize = 2048
[ 1.477418] chip->ecc_strength_ds = 4
[ 1.479752] chip->ecc_step_ds = 512
[ 1.481961] nand: WARNING: pl35x-nand: the ECC used on your system is too weak compared to the one required by the NAND chip
[ 1.492131] Bad block table found at page 131008, version 0x01
[ 1.497074] Bad block table found at page 130944, version 0x01
[ 1.501869] nand_read_bbt: bad block at 0x000002420000
[ 1.505652] nand_read_bbt: bad block at 0x000002440000
[ 1.509471] nand_read_bbt: bad block at 0x000002460000
[ 1.513437] 8 ofpart partitions found on MTD device pl35x-nand
[ 1.517959] mmc0: new high speed SDHC card at address 0001
[ 1.522516] Creating 8 MTD partitions on “pl35x-nand”:
[ 1.526265] 0x000000000000-0x000002800000 : “BOOT.bin-dts-marker-kernel”
[ 1.532665] mmcblk0: mmc0:0001 SD16G 14.6 GiB
[ 1.537748] mmcblk0: p1
[ 1.543124] 0x000002800000-0x000004800000 : “ramfs”
[ 1.558156] 0x000004800000-0x000005000000 : “configs”
[ 1.573239] 0x000005000000-0x000005200000 : “sig”
[ 1.587885] 0x000005200000-0x000006000000 : “reserve1”
[ 1.603091] 0x000006000000-0x000007000000 : “upgrade-ramfs”
[ 1.618642] 0x000007000000-0x00000a800000 : “upgrade-file”
[ 1.634447] 0x00000a800000-0x000010000000 : “reserve2”
[ 1.652951] nf_conntrack version 0.5.0 (3635 buckets, 14540 max)
[ 1.658249] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.662946] NET: Registered protocol family 10
[ 1.677070] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.681360] sit: IPv6 over IPv4 tunneling driver
[ 1.685508] NET: Registered protocol family 17
[ 1.688577] can: controller area network core (rev 20120528 abi 9)
[ 1.693683] NET: Registered protocol family 29
[ 1.696752] can: raw protocol (rev 20120528)
[ 1.699696] can: broadcast manager protocol (rev 20120528 t)
[ 1.704094] can: netlink gateway (rev 20130117) max_hops=1
[ 1.708485] zynq_pm_ioremap: no compatible node found for ‘xlnx,zynq-ddrc-a05’
[ 1.714444] zynq_pm_late_init: Unable to map DDRC IO memory.
[ 1.718793] Registering SWP/SWPB emulation handler
[ 1.724222] hctosys: unable to open rtc device (rtc0)
[ 1.728210] ALSA device list:
[ 1.729787] No soundcards found.
[ 1.732588] RAMDISK: gzip image found at block 0
[ 4.012317] EXT4-fs (ram0): couldn’t mount as ext3 due to feature incompatibilities
[ 4.029429] EXT4-fs (ram0): warning: mounting unchecked fs, running e2fsck is recommended
[ 4.036659] EXT4-fs (ram0): mounted filesystem without journal. Opts: (null)
[ 4.042487] VFS: Mounted root (ext4 filesystem) on device 1:0.
[ 4.047372] devtmpfs: mounted
[ 4.051802] Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
[ 4.237020] EXT4-fs (ram0): re-mounted. Opts: block_validity,delalloc,barrier,user_xattr
[ 4.263462] random: dd urandom read with 2 bits of entropy available
[ 4.313510] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 4.411823] ubi0: attaching mtd2
[ 4.443073] ubi0: scanning is finished
[ 4.451433] ubi0 warning: ubi_eba_init: cannot reserve enough PEBs for bad PEB handling, reserved 4, need 40
[ 4.460522] ubi0: attached mtd2 (name “configs”, size 8 MiB)
[ 4.464988] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 4.470471] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 4.475988] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 4.481620] ubi0: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
[ 4.486182] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 4.492117] ubi0: max/mean erase counter: 5/3, WL threshold: 4096, image sequence number: 853304230
[ 4.499810] ubi0: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
[ 4.507578] ubi0: background thread “ubi_bgt0d” started, PID 738
[ 4.520642] UBIFS (ubi0:0): background thread “ubifs_bgt0_0” started, PID 741
[ 4.558698] UBIFS (ubi0:0): recovery needed
[ 4.620635] UBIFS (ubi0:0): recovery completed
[ 4.623694] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name “config_data”
[ 4.630203] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 4.639643] UBIFS (ubi0:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 4.648390] UBIFS (ubi0:0): reserved for root: 275879 bytes (269 KiB)
[ 4.653505] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID B303FC80-8A5E-421A-9DBE-7A61221E2C57, small LPT model
[ 4.685986] ubi1: attaching mtd5
[ 4.724843] ubi1: scanning is finished
[ 4.727223] ubi1 error: ubi_read_volume_table: the layout volume was not found
[ 4.733196] ubi1 error: ubi_attach_mtd_dev: failed to attach mtd5, error -22
[ 5.911697] ubi1: attaching mtd5
[ 5.974448] ubi1: scanning is finished
[ 5.985328] ubi1: attached mtd5 (name “upgrade-ramfs”, size 16 MiB)
[ 5.990210] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 5.995882] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 6.001321] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 6.006918] ubi1: good PEBs: 128, bad PEBs: 0, corrupted PEBs: 0
[ 6.011644] ubi1: user volume: 0, internal volumes: 1, max. volumes count: 128
[ 6.017509] ubi1: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 516843184
[ 6.025266] ubi1: available PEBs: 84, total reserved PEBs: 44, PEBs reserved for bad PEB handling: 40
[ 6.033174] ubi1: background thread “ubi_bgt1d” started, PID 751
[ 6.064353] UBIFS (ubi1:0): default file-system created
[ 6.074641] UBIFS (ubi1:0): background thread “ubifs_bgt1_0” started, PID 756
[ 6.122401] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name “reserve1”
[ 6.128589] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 6.137241] UBIFS (ubi1:0): FS size: 9396224 bytes (8 MiB, 74 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 6.145980] UBIFS (ubi1:0): reserved for root: 443806 bytes (433 KiB)
[ 6.151107] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 04AA5079-EA9D-43A6-999F-A3D27EBDFCCA, small LPT model
[ 6.860094] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.888044] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.290771] macb e000b000.ethernet eth0: unable to generate target frequency: 25000000 Hz
[ 7.297570] macb e000b000.ethernet eth0: link up (100/Full)
[ 7.302420] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 23.340780] In axi fpga driver!
[ 23.343853] request_mem_region OK!
[ 23.347253] AXI fpga dev virtual address is 0xcfb90000
[ 23.390708] *base_vir_addr = 0xb031
[ 23.430733] In fpga mem driver!
[ 23.433805] request_mem_region OK!
[ 23.437393] fpga mem virtual address is 0xd2000000
2022-07-14 22:32:01 driver/thread.c:2368:create_restart_monitor_thread: create thread
2022-07-14 22:32:01 driver/driver-btm-api.c:300:init_freq_mode: This is scan-user version
2022-07-14 22:32:01 driver/driver-btm-api.c:2089:bitmain_soc_init: opt_multi_version = 1
2022-07-14 22:32:01 driver/driver-btm-api.c:2090:bitmain_soc_init: opt_bitmain_ab = 1
2022-07-14 22:32:01 driver/driver-btm-api.c:2091:bitmain_soc_init: opt_bitmain_work_mode = 0
2022-07-14 22:32:01 driver/driver-btm-api.c:2092:bitmain_soc_init: Miner compile time: Mon May 30 12:01:39 UTC 2022 type: Antminer S19 Hiveon
2022-07-14 22:32:01 driver/driver-btm-api.c:2094:bitmain_soc_init: commit version: 0c32fe9 2022-05-27 15:29:33, build by: root 2022-05-27 18:07:38
2022-07-14 22:32:01 driver/driver-btm-api.c:1470:show_sn: no SN got, please write SN to /nvdata/sn
2022-07-14 22:32:01 driver/fan.c:247:front_fan_power_on: Note: front fan is power on!
2022-07-14 22:32:01 driver/fan.c:253:rear_fan_power_on: Note: rear fan is power on!
2022-07-14 22:32:01 driver/driver-btm-api.c:1526:miner_device_init: Detect 256MB control board of XILINX
2022-07-14 22:32:01 driver/driver-btm-api.c:1498:init_fan_parameter: fan_eft : 0 fan_pwm : 100
2022-07-14 22:32:07 driver/driver-btm-api.c:1196:init_miner_version: miner ID : 8162a4890dfaa85c
2022-07-14 22:32:07 driver/driver-btm-api.c:1201:init_miner_version: FPGA Version = 0xB031
2022-07-14 22:32:07 driver/thread.c:2378:create_read_nonce_reg_thread: create thread
2022-07-14 22:32:07 driver/driver-btm-api.c:1311:bitmain_board_init: project:0
2022-07-14 22:32:15 driver/driver-btm-api.c:1339:bitmain_board_init: Fan check passed.
2022-07-14 22:32:16 driver/board.c:31:jump_and_app_check_restore_pic: chain[0] PIC jump to app
2022-07-14 22:32:20 driver/board.c:34:jump_and_app_check_restore_pic: Check chain[0] PIC fw version=0x89
2022-07-14 22:32:21 driver/board.c:31:jump_and_app_check_restore_pic: chain[1] PIC jump to app
2022-07-14 22:32:25 driver/board.c:34:jump_and_app_check_restore_pic: Check chain[1] PIC fw version=0x89
2022-07-14 22:32:25 driver/board.c:31:jump_and_app_check_restore_pic: chain[2] PIC jump to app
2022-07-14 22:32:30 driver/board.c:34:jump_and_app_check_restore_pic: Check chain[2] PIC fw version=0x89
2022-07-14 22:32:30 driver/thread.c:2363:create_temperature_monitor_thread: create thread
2022-07-14 22:32:32 driver/thread.c:2373:create_pic_heart_beat_thread: create thread
2022-07-14 22:32:32 driver/power_api.c:99:power_init: power init …
2022-07-14 22:32:33 driver/driver-btm-api.c:216:set_miner_status: ERROR_POWER_LOST
2022-07-14 22:32:35 driver/power_api.c:88:power_off: init gpio907
2022-07-14 22:32:36 driver/driver-btm-api.c:733:killall_hashboard: power off hashboard
2022-07-14 22:32:36 driver/driver-btm-api.c:169:stop_mining: stop mining: get power firmware version failed!
2022-07-14 22:32:36 driver/thread.c:2429:cancel_temperature_monitor_thread: cancel thread
2022-07-14 22:32:36 driver/thread.c:2444:cancel_read_nonce_reg_thread: cancel thread
I upgraded to the latest firmware available on support download and now I am getting Network Status Abnormal… Tried 3 times to upload the Merged Firmware (148mb) for low power spacebar counter mode with no success it does not update . It does not change the date Nov 21 … Check whether the power cord is powered on** . If not, please check power switch or replace the power cord. If the power cord is powered on, please observe indicator light, power supply, and check whether fans rotate or not. If no response, the power might be failure.
Were you on an older version before that was working?
Are you using the correct firmware for your control board?
Did you try reflashing the sd card or web upgrade?
May be that’s the same problem I have, the control board problably is cv 1834
I had this problem, I restored the original firmware for factory, and it’s work.
What is your s19? New 90Th version?
