RX6800 - Efficient Overclocking
indent preformatted text by 4 spaces
Sat Jul 17 20:01:37 +0430 2021
Detected 6 AMD cards
GPU BUS ID : 03 06 09 0f 14 17
CORE_CLOCK : 1300 1300 1300 1300 1300 1300
CORE_VDDC : 800 800 800 800 800 800
CORE_STATE :
MEM_CLOCK : 1068 1068 1068 1068 1068 1068
MEM_STATE :
MVDD : 1360 1360 1360 1360 1360 1360
VDDCI : 800 800 800 800 800 800
SOCCLK :
SOCVDDMAX :
REF :
FAN :
PL :
AGGRESSIVE = 1
e[0;33m===e[0m GPU e[0;36m0e[0m, e[0;35m03:00.0e[0m e[0;31mRadeon RX 6800 16368 MBe[0m #1 e[0;33m=== 20:01:37e[0m
e[0;36mDefault Power Play settings from VBIOS for Navi20e[0m
CORE Clock max: 2600MHz, Voltage: 793-1025mV, SOC Clock: 1200MHz, Voltage: 925-1050mV
MEMORY Clock def/max: 1000/1075 MHz, Voltage: 1250-1350 mV, VDDCI: 675-850mV, TC: 1
POWER PL: 227W OV: -8%/+10%, TDC GFX: 235A, TDC SOC: 30A, TEMP Target: 90C
e[0;36mApplying changes to Power Play table e[0m
SOC: e[0;32m1200MHze[0m@e[0;32m1050mVe[0m (TDC Limit e[0;32m33Ae[0m) VDDCI: e[0;32m800mVe[0m MVDD: e[0;32m1350mVe[0m
e[0;36mApplying OC via SysFS API e[0m
Setting CORE: e[0;32m1300MHze[0m@e[0;32m800mVe[0m MEM: e[0;32m1068MHze[0m
Setting Fan speed set to Auto (HW)
e[0;33m===e[0m GPU e[0;36m1e[0m, e[0;35m06:00.0e[0m e[0;31mRadeon RX 6800 16368 MBe[0m #2 e[0;33m=== 20:01:40e[0m
e[0;33m===e[0m GPU e[0;36m2e[0m, e[0;35m09:00.0e[0m e[0;31mRadeon RX 6800 16368 MBe[0m #3 e[0;33m=== 20:01:42e[0m
e[0;33m===e[0m GPU e[0;36m3e[0m, e[0;35m0f:00.0e[0m e[0;31mRadeon RX 6800 16368 MBe[0m #4 e[0;33m=== 20:01:44e[0m
e[0;33m===e[0m GPU e[0;36m4e[0m, e[0;35m14:00.0e[0m e[0;31mRadeon RX 6800 16368 MBe[0m #5 e[0;33m=== 20:01:46e[0m
e[0;33m===e[0m GPU e[0;36m5e[0m, e[0;35m17:00.0e[0m e[0;31mRadeon RX 6800 16368 MBe[0m #6 e[0;33m=== 20:01:48e[0m
1068 cause more un stable
i sue
A20.40 (5.9.0325)
you need update your installation with new image (OpenCL 20.40 amdgpu 5.11.0701)
in ssh => hive-replace -s will do the job
this cause me 2 times waste my times because after that nothing works correctly
new installation better idea
tomorrow i will update
I tried updating to 0.6-205 as well and got a lower hashrate, higher temps, and higher watt output using Redminer. I ended up reverting back.
If you update through the Hive OS portal for whatever reason it doesn’t update the AMD driver to 5.11.0701. You need to start a shell then update via hive-replace and select the install version that has that AMD driver. Here are my settings using PM
Thank you, helped me a lot.
PS: you don’t have to cover your internal ip, it’s unaccessible from the outside.
99% - 192.168.0.xxx :smiley:
Hi
i download new image and run
still does not have same hashrate on GPU with 1300/1068
and one card missing i think because of this erro
not quite so … this is a consequence. Overclocking cannot be applied because the driver for some reason (riser for example) could not correctly initialize this card
thanks
and what do you think about first part
why i have not same shashate while i have same card same bios number and same setting
For some reason phoenix miner is working again and I have a good hashrate
From the changelog (yes, you need to upgrade and include the updated driver):
  • AMD driver: v5.11.0701 (supporting the latest “Big Navi” GPUs including RX 6700XT/ 6800/ 6800XT/ 6900XT)
  • reworked overclocking procedure for AMD Vega20/Navi/BigNavi GPUs (extends acceptable limits for clocks and voltages, reworked BigNavi OC - need AMD kernel module v5.9.0501 or later, added software unlock to support OC/UV for Radeon Pro W5x00 GPUs, fixed bugs)
EDIT: the regression has been introduced in version after 0.6-206@210723. 0.6-205@210723 is not affected.
I have some strange results with an AMD rx 6800 reference card:
I can get 56-58 MH, 97W card / 160w wall, 625mV VDD, 755mV VDDCI, 1255mV MVDD.
But, if I reboot, power consumption jumps to 107w card / 170w wall. Measured with a smart plug.
I’m seeing such low power consumption only after a “hive-replace” on first boot. On subsequent boots, my card is stuck at 106-107w, same hashrate. Confirmed at the wall: +10w (170w vs 160w).
Also confirmed by temperature:
  • At 97w, Core 56°C, Hotspot 61°C and Mem 68°C,
  • At 107w, Core 60°C, Hostspot 65°C and Mem 72°C.
amd-info:
=== GPU 0, 07:00.0 Radeon RX 6800 16368 MB ===
Bios: 113-D4120900-101
Core: 1150 MHz 612mV, Mem: 1000 MHz
PerfCtrl: manual, Load: 99%, MemLoad: 100%, Power: 97.0 W, Cap: 203 W
Core: 56°C, HotSpot: 61°C, Mem: 68°C, Fan: 44%, RPM: 1485
Core state: 1, clocks: 500 1150*
Mem state: 3, clocks: 96 456 673 1000*
SOC state: 1, clocks: 480 685* 1200
DCEF state: 1, clocks: 417 872* 1200
F state: 1, clocks: 500 1119* 1551
PCIE Link speed:n/a, PCIE Link width:n/a
Memory total: 16368.00 MB, used: 4492.09 MB, free: 11875.91 MB, type: Samsung GDDR6
amd-oc log:
Mon Jul 26 16:14:46 CEST 2021
Detected 1 AMD cards
GPU BUS ID : 07
CORE_CLOCK : 1150
CORE_VDDC : 625
CORE_STATE :
MEM_CLOCK :
MEM_STATE :
MVDD : 1255
VDDCI : 755
SOCCLK :
SOCVDDMAX :
REF :
FAN : 46
PL :
AGGRESSIVE =
=== GPU 0, 07:00.0 Radeon RX 6800 16368 MB #0 === 16:14:46
CORE Clock max: 2600MHz, Voltage: 793-1025mV, SOC Clock: 480-1200MHz, Voltage: 925-1050mV
POWER PL: 203W OV: -8%/+15%, TDC GFX: 200A, TDC SOC: 30A, TEMP Target: 80C
Warning! No memory clock is set or out of range - using 1000MHz as fail safe clock
SOC: 1200MHz@1050mV (TDC Limit 33A) VDDCI: 755mV MVDD: 1255mV
Setting CORE: 1150MHz@625mV MEM: 1000MHz
=== /var/log/amd-oc.log === 2021-07-26 16:14:47.388507710 +0200
@vanadium Hello I have two cards with little bit different settings but they are working at 60-61mh/s. I think you need to overclock your RAM maybe to 1060. And how do you measure power consumption with motherboard and everything or power supply is only for GPU? Because I measure less than 300W with two GPU’s motherboard additional fans and everything.
i have same card the hight i get was 56 mh,it was 61 before but it restarst every 5 min
Maybe wrong overclock settings or wrong miner sometimes Phoenix miner is really unstable you can try with Teamredminer clear all overclock/undervolt settings set core to 1300-1400 memory to 1050 and start mining if you get stable results you can try to overclock little bit memory to 1060-1070. When everything is ok with overclock you can start with undervolt first core and step by step all settings.
hive-replace -y --stable
if you’re still having a higher wattage than 120w for your cards, you should do the command above. it should update you to the latest version of the kernel, which includes the AMD driver update.
After trying many OC setting, bellow is the most stable ( XFX RX6800)
I recommend also to check the hashrate and valid share % in Ethermine website, the payout depend on this value,
Good luck :v:
