I am pretty new to mining and I have an AMD/ATI 6700 that is consistently running at a higher temp than my other Sapphire 6700. I have been messing around with the overclocks to see if I could possibly see if I could lower the temps to a safe level. Am I ok with having the Mem temps at 80-85 degrees or do I need to aim lower. As you can see from the picture the fan is blasting at 100% just to try to keep it at 80 degrees.
Side note: I have been trying to add a rx5700 to my rig and have been running into some major problems. If someone has some better experience with this I would appreciate the assistance.
