So I’m experiencing a somewhat odd issue… I’m really hoping there’s a software solution to this but here we go…
I repasted and repadded one off my Sapphire RX580 4GB (Elpida) and when I put it back into the rig it shows up but it doesn’t display any info. I’m using a BTC-S37 board and it’s working fine with all the other cards. I tried putting the card in my stationary computer and it doesn’t show up in windows.
In overview it shows up like this, I included one of the working cards for comparison.
It shows up like this in GPU hub
It gets even weirder as I can flash the card with differentet vbios and download them from card verifying that they’re not fuzzed/f#cked up. My fear is that something has broken on the card like the IMC or anything related to memory. My reasoning for this would be that the card doesn’t show the amount of memory on the card however it displays the correct VBIOS and the VBIOS seem to be intact (all timings and voltage settings are equal to my other 5 cards).
Any help or insight here would be greatly appreciated, hoping that I won’t have to send this to be repaired.
When digging through the logs I found this, not sure what to think of it. Seems to be some kind of kernel error but by that logic my other 5 GPU’s of same make should not work either?
