Hello miners,
Does anyone haves problem like this on the picture bellow.
This morning the problem appear with one my card at 4 5700xt cards rig.
Last night i do selfupgrade, apt update and apt dist-upgrade on all my rigs. Only rig with 5700xt cards have this issue.
I do some troubleshooting and check following
- check risers on all cards
- check PSU
- check cables and connectors
and everything looks good to me
i try to figured out what is problem and do checking cards one by one till other cards was detached completely from rig. ALL cards starting and mining well with around 55mhs just as worked before incident.
BUT when i connect two card, any combination, or three cards or all 4 cards, one card , specifically card which are at current setup at first position don’t show sensors at HiveOS nor at miner console but still mining with lower hash rate.
I am thinking first that miner is the problem and i try to choose some older version but i get the same error and issue - using Phoenix miner
Also, i notice that card with red cross that is always card which is in the current setup at first position (miner shows it as GPU1) gives around 4mhs less then others, around 50mhs
I try also - to switch risers between cards - issue persist
- try to switch card position - issue persist
- try to use brand new riser - issue persist
My conclusion is that cards are not damaged, risers are good and not damaged also.
I doubt that power supply unit maybe faulty - what is the best way to check it ?!?
Also i doubt that software maybe cause problem - maybe latest version of HiveOS or drivers or something at linux system
I appreciate if anyone can help. Any opinion will help.
