Hi. There are 3 cards in the system. After the power cut, the 2 cards that are later show 10 mh missing. I changed their location. In the same way, number 1 gives normal mh. Numbers 2 and 3 are 10 mh low. What do you think? Have you ever encountered anything like this?
Have you vbios them?
Yes. There is, but when gpu1 and gpu0 are replaced, this time that card gives normal mh value.
Well when you replace slots, maybe thay are on same possition in hiveos, you need to go oc vbios one by one card to get 30+ mhs, I can help you with that
