RX 6700xt kawpow OC
hello TTorres, I have 6700 qick and merc, also 1 power color but I would like to know what model do you have?? my overclock is this and I would like to lower the voltage a little more, what could I do???
thanks
thank you but with this oc my wat is above 138 watt
hi
thank you for your guid
when i set that oc whitout “core voltage” and “memory controller voltage” i got 24.5 Mh with 115 watt
thank so much
did you set Soc VDDmax too?
i did set all of parameters that you said but I did set core voltage and memory control voltage with empty (0)
my problem is my watt because be above 110 wat did you know any solution for decrease my watt to below 100 watt?
Looks like your only option is to bring down the core mhz to lower your usage.
I got mine at 21mh+ at 73watts± software reported
use this oc
You need to set soc VDDmax to 850
do you know any oc for 6700 xt quick and merc?? , for firopow is the same oc???
try CORE at 1550, I got a steady 26.80 hashrate with little more watt
