Hi is this memory temperature of 82-86 ok?
I made a fan speed from 80-100
Hasrate is good 47.04
I am suffering the same issue. The mem temp for the AMD/ATI gpu go above 100C.
The XFX and ASROCK don’t have the same issue.
The AMD /ATI’s are crashing when the mem temps are above 105C so i needed to clock down.
Tried many combo’s with teamredmider, phoenixminer and now lolminer, but the issue still persist.
I am also looking into the solution.
Thanks I will try now
Is normal Vram Temp in 70 ° Range ?
