Rx 6600m vbios flash to ordinary rx6600 possible?
Hi all, I bought cheap soyo rx 6600m from AliExpress.
In windows it is very limited in adrenaline drivers without option to undervolt or overclock, and it’s original bios is annoying with fan curve that has only two speeds (1500rpm idle ,2500rpm load).
I didn’t try the card in hive os yet, but was wondering if it’s possible to even flash it with xfx or gigabyte vbios for example. I have found quite few versions of vbios from different manufacturers and willing to try.
Thanks.
sounds like some have tried on reddit but not with full success. if you have a bios flasher tool you should be able to recover from any failed flashes also.
