Hi, does anyone knows how can I lower of wattage from 107w to 90w on the rx580 xfx hynix GPUs?
**Hi, does anyone knows how can I lower of wattage from 107w to 90w on the rx580 xfx hynix GPUs?
**i looking for another topic and solved my problem
one way is ![]()
another way is this
Also fix your fan speed at 5700xt …you are over limit…on temps!!!
