Hello there i have sapphire rx 580 x 9 running with no problems at all using teamredminer. I bought one rx 5700 and want to add to same rig . If i am running rx 5700 alone it will give me around 54 mh/s. When i connect this card with other rx 580 cards in rig, rx 5700 not detectable. Any thoughts how to make it detectable , tried so many ways with no success. Thanks
Put your 5700 into pci-x 16x …
Thanks i will try that .
A typical problem with Polaris (400- and 500-series) and Navi (5000-series) cards mixed together in a rig running TeamRedMiner is one or 2 GPU’s not initializing.
This is a known problem with the latest AMD driver. I would suggest using an older AMD linux driver from the beginning of the year.
