Hello Can some help what here is wrong.
i try ed to mode but nothing hep
Hello! If I were you I would remove all card and leave only 1 r570 which have low HR. Then I will reset RX570 boost settings to default, and enter this card to pci socket in motherboard. If after that you will have same low HR problem most likely in this card if you will have normal HR this card is ok.
how to reset a vga to default?
