Greetings,
My card Sapphire Nitro RX 570 4GB is providing 24.4mh/s (very stable) but that is only when i mine on my PC. Moving the card to my rig, it can’t go over 20mh mining Ethereum.
Both setups are running same hiveos versions, the card is connected to pcie x16 port, using the same flight sheet and overclock.
So yeah, the only difference is motherboard, power supply, ram memory and proccessor.
Pc config:
Motherboard B250M PRO-VD (MS-7A74)
CPU 4 × Intel® Core™ i5-7400 CPU @ 3.00GHz
RAM 16GB ddr4
SSD 128
650w power supply
Rig config;
Motherboard TB250-BTC BIOSTAR
CPU 2 × Intel® Celeron® CPU G3900 @ 2.80GHz
RAM 8GB DDR4
SSD 128
1200w power supply
What could be the issue? I don’t get it.
