I’m using rx 5500 xt sapphire micron (28.3 mh/s, 66W) and rx 580 MSI micron (32.16 mh/s, 83W) with best overclock settings available on hiveos. But whenever power loss occurs after Starting rig the Rx 5500xt won’t mine automatically and limits to 23-27watts then after removing the oc settings manually the card starts mining 25.3 mh/s on 63watts. Can anyone help me please ?
*Should i downgrade rx 5500xt driver ?
Open your miner inside the shell and see what it says
My 5500XT with micron memory will run 960+ Memory after boot, but with exhibit the systems you see or worse lock the rig up entirely(990) when too high.
See if the situation goes away at 950 Memory as a test.
