[quote=“Isnobad;2111”]Ok… here a 100% Noob-Proof How-To
Based on a fresh Flashed HIVE
// Uninstall the GPU Driver…
- We need to unpack the Driver an install it for a right Uninstall
So we do:
[b]
cd /hive-drivers-pack
tar -Jxvf amdgpu-pro-17.50-511655.tar.xz
cd amdgpu-pro-17.50-511655
bash ./amdgpu-pro-install -y --compute
amdgpu-pro-uninstall
[/b]
Confirm with “y”…
// ok now REBOOT
[b]
reboot
[/b]
// after that
[b]
wget http://download.hiveos.farm/kernels/linux-headers-4.13.12-mytest_1_amd64.deb
wget http://download.hiveos.farm/kernels/linux-firmware-image-4.13.12-mytest_1_amd64.deb
wget http://download.hiveos.farm/kernels/linux-image-4.13.12-mytest_1_amd64.deb
[/b]
// And install it
[b]
dpkg -i linux-headers-4.13.12-mytest_1_amd64.deb
dpkg -i linux-firmware-image-4.13.12-mytest_1_amd64.deb
dpkg -i linux-image-4.13.12-mytest_1_amd64.deb
grub-set-default "1>0"; update-grub
[/b]
// ok… again… reboot
[b]
reboot
[/b]
// after that we install the working Driver, in my Case… the amdgpu-pro-17.40.2712-510357 works great for RX 550 560 570 580…
[b]
wget --referer=http://support.amd.com https://www2.ati.com/drivers/linux/beta/ubuntu/amdgpu-pro-17.40.2712-510357.tar.xz
tar -Jxvf amdgpu-pro-17.40.2712-510357.tar.xz
cd amdgpu-pro-17.40.2712-510357
[/b]
// reboot an happy Mining… o.O
[b]
reboot
[/b]
Say thx 2:
ETN: etnjxU2vdq2UfQaBahApNrNSQuifB4JVXV5FK2HPp4TnbEv1xWh7QYfHYfprpRMgxMXQgv7wDwStmUcybVuVCnbY4fQu5WLDxn
ETH: 0x6dBfcE437fB8Ee49188e76560bb1A58Df5Ebb133
XUN: Xun3PHT9D4RiY75B5BMvnRdTeg6mtXjr7WZsvCkbeT98FLXyrGQW6rkBv1rJxPhGvpfFMiQMzxevxF419b7oKeun7HUqwmmCBR[/quote]
Hi there,
I tried your method, however, after I got to the stage of installing new kernels I got a blank screen once I rebooted. Any ideas?
I did this using the latest version of Hive
i’ve just unlocked 2 more cu on chinastyle rx550, open rom with hex editor and search for 6F 22 70 22 and change it to 6F 22 6F 22, save it, than open with polaris bios to fix checksum, flash it and then atikmdag-patcher and you should end with something like this:
so now it mines as good as lexa if not even a little better
cheers
I find the Elpida memory mines way better in the 550 then other memory.
Nice work, will try it Saturday, when I change out my 550 system to only be 550 cards.
One good guy Alecsandro from HiveOS Telegram chat helped me update my HiveOS with 5x Gigabyte Radeon RX 550 / 2GB DDR5 / 1 x Fan / Hynix for new CryptoNight new algos. So…
- Install http://193.111.83.51/test/hive-0.5-20-rx550_sgminer.zip with one connected card and start rig.
- Type :
apt-get update
- Type :
apt-get upgrade
- Power off.
- Connect all your cards.
- Mine! Use XMR-STACK with config like this (on card on two ways):
"gpu_threads_conf" : [
// gpu: gfx804 memory:1395
// compute units: 8
{ "index" : 0,
"intensity" : 456, "worksize" : 12,
"affine_to_cpu" : false, "strided_index" : 2, "mem_chunk" : 8,
"comp_mode" : true
{ "index" : 0,
"comp_mode" : true
{ "index" : 1,
"comp_mode" : true
{ "index" : 1,
"comp_mode" : true
{ "index" : 2,
"comp_mode" : true
{ "index" : 2,
"comp_mode" : true
{ "index" : 3,
"comp_mode" : true
{ "index" : 3,
"comp_mode" : true
{ "index" : 4,
"comp_mode" : true
{ "index" : 4,
"comp_mode" : true
"platform_index" : 0,
Don’t forget set the algo type in wallet config override settings like a
"monero": "true"
My OC settings with boost & downvolt.
Sorry for my eng
Good luck miners!
Всем привет,помогите с монеро, никак не могу настроить карту выше 360 хешей на монеро V7 ,карта выдаёт около 500 в винде, а вот в линуксе настроить не получается, Прочитал всю тему и не один раз.Первые страниц 6 тупо про старый алгоритм.(где-то разные настройки не работают,где-то дают не полную инфу)
Как же всётаки начать майнить новый алгорит монеро V7 монету монеро с хешами с хешами близкими к 500,спс
Биос перешивал?
Да прошитый и в винде выдаёт своё. А в линуксе что-то гемор.
Ставь это http://193.111.83.51/test/hive-0.5-20-rx550_sgminer.zip
Потом обновись до последней версии
Используй майнер XMR stack
Вот настройки для 12 карт. Если другое количество то добавь или удали
“gpu_threads_conf” : [
{ “index” : 0, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
“comp_mode” : true },
{ “index” : 1, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
{ “index” : 2, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
{ “index” : 3, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
{ “index” : 4, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
{ “index” : 5, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
{ “index” : 6, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
{ “index” : 7, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
{ “index” : 8, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
{ “index” : 9, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
{ “index” : 10, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
{ “index” : 11, “intensity” : 432, “worksize” : 12, “affine_to_cpu” : false, “strided_index” : 1, “mem_chunk” : 1,
“platform_index” : 0,
А можно вас попросить показать скриншоты результата,и собственно настроек валета,конечно сам адресс и что считаете нужным закрасте спс.
в целом всё заработало,спс,правда на одной из 3 ферм после перезегрузки просто пишит ошибку opencl файла.но думаю разберусь,Спасибо ещё раз.
Hi;
How to mod my RX550 GPUs ? I have downloaded the bios. What should i change ?
Elphida 10 compute unit.
I use xmr-stak indeed miner.
Hello i can’t extract the image iso of http://193.111.83.51/test/hive-0.5-20-rx550_sgminer.zip error 0x80004005 What can i do?
Finally, i see 486 h/s with xmr-stak on windows. But i see only 405 h/s with xmr-stak on Hiveos. i use the same rom and config but i couldnt find the reason of the lower hashrate on Hiveos.
Ребята, у кого есть опыт разгона ChinaStyle RX 550 4096M
Micron MT51J256M3, 113-367BF-U41 (здесь выдают 10мх, а в Вине давали 13) и желание немного подзаработать - помогите мне по скайпу или вотц. Могу завтра с утра в течение дня. (Буду благодарен, если напишите в личку)
Наверное, сегодня занятый день у всех(
Напишите, пожалуйста - когда у вас будет время (я подстроюсь)…
PS. А когда разгоню - напишу здесь (чтобы закрыть запрос))
После установки обновы 0.5-54 произошёл казус - сначала упала в оффлайн одна карта, после принудительных мучений упала и ферма(зависла). Я один счастливчик или ещё есть?
Так же не понятно ведёт себя майнер xmr-stak - при рестарте майнера он не запускается и требуется рестарт фермы. На 0.5-53 и более старых версиях подобных проблем зафиксировано не было.
А, и ещё одно дополнение - даунгрейдится не хочется - Aero карточки на этом билде стали выдавать >500hs при не очень экстремальном разгоне (1203@850mv\2050)
Не актуально - во всём виноват новый алгоритм разгона\даунвольта. Буду подбирать параметры…
Начни с 1200 по ядру, 2000 по памяти. Биос естественно прошей.
А дальше ищи стабильности по разгону и делай даунвольт. Ничего сложного, просто надо подобрать актуальные параметры для твоих карт.
