RX 480 Power & Temp
Some days ago I saw that I’m getting a new error on hive about temperature ( 511 degress and over 1000000 W) on a RX 480 Sapphire Nitro+. I tried to change the PCI Slot, Change de riser, change the power cable at riser & GPU, I tried the gpu in a normal PC I also tried to change de gpu bios, and I still can’t find the problem. If someone knows a solution I would be so thankful.
Thank you!
Did you update the system?
I tried on 2 different systems, one with hiveos latest version and windows 10 64bit up-to-date, different versions of amd drivers.
