Run script when hashrate watchdog triggers reboot
What is the ‘best’ way to have a script run when the hashrate watchdog decides it should reboot?
I could simply edit /hive/bin/wd and insert the command to run the script, but messing with ‘os’ files seems bad as on a practical level, any updates could overwrite it.
