Does anyone have experienced the following issue:
If I enable the function to delay the OC when the miner starts and after the delay time (60secs) I’m getting a lower Hashrate (1/1.5 MH - 60.50 instead of 62.5) on 2 of my cards (1 RTX3070 and 1 RTX3060TI).
Even if I try to re-apply the correct OC using the GUI the OC won’t reach the normal values. To fix the issues I have to delete the delay, reset these 2 cards’OC values, restart the miner, wait for the DAG creation and then re-apply manually the OC values.
That’s really strange… My question is: how the OC delay
function can influence the maximum card’s Hashrate?
Is it possible that higher OC values during DAG generation phase can improve performance but decrease stability?
