Just tested, with 6 x RTX3060 I get about 26,5 MH/s per GPU
with hdmi dummy, gen 3 settings and T-Rex miner
Thanks a lot extremejojo, i just tried those and i got my cards to the same levels like yours, without dummy plugs! will see how long it will run like this
yours are running hot looks like, my fan is like 50 and i got stable temps so far…
i am getting Invalid shares error, for few hours i got only 1…but still…i think it needs more tweaking.
otherwise they are running nice and cool, no issues there, but i need to fix that issue eventually
any ideas?
Hey , I have 5 rigs with 16 rtx 3060 and the best I got was 22/mhs using core -100 PL 100. Ive tried diff combos but anything higher /closer to 30 mhs is o
verheating .yeah im using the biostar t360 board… Its ok . Just feel there is limitation with legacy and UEFI settings
I am getting 26.47 without any problems!
core - 60
mem - 2550
PL - 125
my PL is 55 but you adjust that based on how hot they run…
Thanks , when up the mem to 1500/2500/2800 with core -100 and watt 95 the temp hit 75-80 with lil improvement. How are you handling the offline/online issue and invalid shares ?
use T-rex - not phoenixminer! otherwise you will get those errors right away, so far, for few days i have 0 issues with T-rex.
Update your hiveOS
try to use my settings, i have been testing many different one, and so far it works great for me.
Core 60
memory 2550
PL 125
fan - mine is 50-55 depends on the day, but never over 60 and my max temp so far i have seen in 60, and its not in cold room, AC running - just a living room that i dont use.
95 watts - you cant run it - gotta go up on the wattage - try and I hope it will work for you
let me know
Thanks , will trex work if im using ethash with nicehash wallet ?
I have two 3060 and they are 25.90MH on Eth. Using the new core clock settings. 73/78 watts, Core 1300, Mem 2700.
Wish there was a work around for them to get full hashrate on risers and in Hive. Theres a few videos on youtube with rigs using full size risers and 6 cards on a rig at full 50MH.
They use MB wit 6x PCIe 3.0x8 slots
OMG. No offense. But this is probably the worst mining setup I’ve ever seen. A melting pot of useless GPUs converting tons of electrical power straight into heat. I guess your electricity is super cheap.
Actually … this is the complete set with a 2 ton ac and heat fans to extract the hot air. No offense … you should probably ask how im cooling things down b4 you make a comment
the temps
No need to ask. I see exactly how you cool it. 2 ton ac and a few box fans are not enough. Why am I saying this? Cause I have exactly the same set up )))))). I rebuilt my rigs to separate the cards further. Hey, if it works for you, that’s fine. As I said, no offense. Good luck with those 3060s. If you need couple more I can sell them to you. ))
Yeah , I know no Offense taking. Im using the btc bio star boards that are raiserless … I wanted to deal with a setup without having to replace failing raisers are the time . Also in the hice os im running the auto fan which helps. However just recently I dropped hiveos and move over to nice hash. If you have anyother company for mining let me know
ty
