Has anybody experience about the actual status of the RTX 3080 LHR?
Which ETH Hashrate is possible and how the power consumption is?
I´ll get 70-72 mhs with mi 3080 LHR… an NBMiner (latest).
Got some issues with my second card (only 60-65 mhs)
Hi, can u share ur oc settings how to get 70 -72 MHs please? thank you
thank you for sharing your oc setting, seems each 3080 LHR card has different oc setting even the same model card also different memory type I think
Yes, same cards… but on the second one the power dropped - 30w after 10-15 min on 200w…
probably memory temp junction?
Great, yes… that was the problem
Thx!
Just turned the fan speed on 90-95 an got now 69…
I think I have to rebuild the reg…
Hi all, im new to mining and have 2 rtx 3080 lhr gpu’s, i started mining with trex using oc settings core 1400 memory 2600 and power at 280, with this settings i achieved 75mhs per card but rig was never stable, yes i achieved a good150+mhs but also had alot of invalid and stale shares…
Rig also went offline atleast 4 times a day and the latter even went offline for 45 minutes, yes it was getting worse…
I read through all the forums and found my oc settings was the main culprit, i somehow got this settings some where and it was stable for a week only got 1 invalid share for the entire week, rig is now stable and my fan speed that used to be 80% is now 70% which is less noisy, i only achieve 140mhs for both cards but im happy that rig is stable and not switching off
Hi, is your hashrate stable at 77mhs, what’s your overclocks and which miner are you using
I found that locking the core clock to 1375 and memory to 1400 ( 2800 ) results most stable performance, without constantly unlocking LHR from the miner ( T-Rex ). Give it a try
Your card has fully unlocked performance, it might not be LHR at all.
No its lhr v2
It is * GeForce RTX 3080 - GA102-202 (PCI Device ID: 2216) in GPU-Z?
Hi there! Please share miner y OC settings. I can olny get 72 of my 3080 with Core -200 Mem 2000 PL 230 in gminer.
Yo obtengo 77mhs ocn oc 1500 y 3400 PL 0, y temp en 56° estan mas esos valores?
With LHR version that’s the most, you can get.
I doubt that Sparta has LHR v2. He is neither communicative nor willing to share.
