Rtx 3080 Asus tuf oc and Rtx 3070 gigabyte vision
Got problems with no fan controls they work sometimes for few seconds but 90% of time nothing causing overheating
Tried updating drivers bios etc
Works perfectly in windows
I’ve got 3080 suprem x and game rocks and others working 100%
Just hating the fact I’ve got it go back to windows for these
Any suggestions ?
Have you set the fan of the gpu to 0 (auto) or have you set it ?
I’ve tried setting it to 0 but get no gpu temps error
The only way I can get it to work without issue is set to 65 all the time and increase when needed
I only get this issue on 3080s 3070s set to 0 no issues
Hello
Did You fix it ?
Have the same problem with fan
It’s random. Not only on one card. Sometimes on card 3, sometimes on another
AORUS GeForce RTX™ 3070 MASTER
nvidia-info | grep Fan
PSTATE P2, PWR 130.0 W, Temp 60 °C, Fan 51 %, RPM 862, Fan 51 %, RPM 866
PSTATE P2, PWR 120.2 W, Temp 61 °C, Fan 70 %, RPM 1644, Fan 70 %, RPM 1643
PSTATE P2, PWR 116.9 W, Temp 62 °C, Fan 0 %
PSTATE P2, PWR 121.3 W, Temp 60 °C, Fan 61 %, RPM 1276, Fan 61 %, RPM 1274
It have to be switch off competly and after - it could work (or not)
Yes the only way I can get it to work stable is to set fans to 65 and if it gets hot I increase as needed I’ve turned off auto fan that caused a lot of issues
I don’t let gpus get above 59degrees on the 3080s
And not above 62 degrees on the 3070s
Been working now for weeks no issues
I have two ASUS 3070s and they are “working” ok with autofan/smartmode. (70c,90c,33%,199%)
Spinning 50% speed, <50% of the time. I am not-a-fan of the on/off cycles. Might try some different options to run slower, but more consistantly.
