yes, photoshop - u got me
Hi folks,
Do you have settings for the Asus GeForce RTX 3070 ROG Strix O8G?
I would be very grateful!
ı got 63,82 mh. msi 3070 gaming trio
Samsung GDDR6 · 94.04.3A.40.90 · PL 100 W, 240 W, 250 W
63.82 MH
TEMP: 36°
FAN: 64%
CORE: 80
MEM: 2980
PL : 135
aşırı fazla değil mi ? vram ne durumda ? yanıyordur hocam biraz daha çek aşağıya
paylasım hatası alıyor musun pekı bu sekılde ? guzel deger vermıs
daniel, how do you get to those numbers e.g. which are the values you start off with and then what kind of increments do you use? also what is your ambient temp?
i switched from phoenix to trex and got a nice boost in terms of hash rate and lower consumption
this is insane, how do you keep it at 36C?
paylasım hatası almıyor hocam sadece internet gıderse alıyor gunde 1 2 alıyor max oda superbox ile oldugu ıcın.
deneyecegım hocam tesekkur ederım -500 2200 130w yapınca ben 58 mhs alıyorum sınır oldum kac gundur ugrasıyorum cozemedım
hello i have asus tuf and msı gaming x trio cards. but I have problems with overclock settings. can you check it and write what is most suitable for me? thanks in advance.
I get about 63.1 MHs with these settings on EVGA 3070 XC3 Ultra
hi,i am a new miner,only try mining about 2 weeks, this is my overlock give me an advice, thanks, too hot 53-57° .
GPU 0
GeForce RTX 3070 7982 MB · Gigabyte
Samsung GDDR6 · 94.04.3A.40.DB · PL 100 W, 270 W, 270 W
63.49 Mhs 53° 75% 75 -502 2900 132w
GPU 1
GeForce RTX 2070 7979 MB · MSI
Micron GDDR6 · 90.06.0B.40.12 · PL 112.5 W, 225 W, 250 W
43.63 MHs 46° 75% 75 -200 2050 126w
hi there how you can get 33° ? i got this :
I start the rig, stop the miner, change the setting to the ones with 117w to all the 3070s and than hard boot the rig again.
After the I check with ones will get those number and change the others to spend more power.
I’m in Brazil, today we have 30ºC as ambient temp
Those are my settings now
You can really lower your temps a lot by trying this:
This is also at 30C ambient or higher.
Your core voltage is way too high for no good reason. Drop it and then you can drop voltage significantly - hopefully if you have a good gpu model.
This is EVGA 3070 XC Ultra.
