I’d say silicone lottery was bad on that one.
For your fans.
Set up the Auto fan to 50c temp, then apply it, then go into the Overclocking and set all fans to “0”.
That will maintain a consistent core temp.
For your fans.
I only talk based on experience, a part from that I always have the automatic fan option on so my fans are at 70% but if the temps get too high the fans will go higher anyways👍
Auto fan maintains the core temp, Not the fan speed. Fan speed changes based on the core temp you set.
If your fans are set for 70, then thats manual.
Lol. Smart mode doesnt work like you think.
Thats your problem.
Shut off smart mode and thank me later.
not having any issues and really happy with it for now !
So u like higher temperatures when its hot?..
Lol.
Shut off smart mode. You want a constant cool temp
i guess i’ve never been in high temp on that rig so couldn’t tell that was useless
Show me ur temps
What about fan speed, im not allowed to see that?.lol
And your temps dont need to be that low, 50c is fine.
Slow down ur fans and save ur watts and hashrate, depending on GPU.
50c Autofan and shut off smart mode.
Thank me later, ive been thanked before…lol
Your attitude is so bad lmao, no you are not allowed to, i’ve showed you my autofan higher you can see they are at 65%
Sorry for trying to help u save ur GPUs…lol
My bad.
You don’t need ur fans running at 65% minimum if your gpus are in the 30s…lol
Smart mode is so smart its making u run almost 20degress less than ur setpoint, it makes no sense at all. …lol
Shut off smart mode and set minimum to 25 or 30%.
And watch ur watts drop off a little.
Serg #0208
lol its fun to watch when experts are talking and trying so hard to prove their point
Hi guys,
i am new in mining, i make one rig yesterday,i read on this forum about overclocking card and i make mine to perform well.
This is my first rig and soon probably one more.
This is result,thx for your comments,lot of help to me.
Set core to Absolute core.
Erase -502 and put in 1100. Watch ur power drop and hashrate stay put.
Best thing Hive ever did
Tnx for advice,i used it and hashrate still same and power is lower,is hive os good for reading power of rig?
You really need a smart plug in the wall to get the true power draw for the whole rig.
How much did you drop in Hive?
