Hi, I’m new to the mining, I’m using a hynix memory 3060ti LHR, recently trex dropped full unlock lhr on dual mining. Can anybody tell me what are the good overcloak settings for dual mining since trex didn’t mentioned values for 3060ti ? also what is the password in Trex config for dual mining?
best practice it trial and error to see what gets you best results. with trex dual mining youll want to optimize settings for the second algo alone, and then setup dual mining. 1500mhz on the core clock is a good starting point.
password field should be able to be left blank.
