Hello guys,
What do you think of these Clocks?
I spent a few hours testing each gpu and noticed that each behaves differently.
I noticed that if the temperatures increase, the rig generates a gpu temp error and restarts. I think it might be very hot memory. Now I’ve installed 120mm 1700 RPM fans and have been stable for the last 24h.
Best regards from Lisbon
Try the core between -300 and -310.
Es mucha velocidad 2700 memoria clock
It’s a lot of speed 2700 memory clock???
Can you share the miner configuration photo
Cab you share a miner configuration page photi
121.4mh
37c
65% fan
97w
1500 core
2200 mem
460.39 driver
on my 3060 v2 lhr i can get 117MH (ergo) but i got inconsistency. I set it down to 108 and then a good average in the pool.
c1267/m2660
pl107 but NBminer 39.4 keeps at about 85w
My best result with 1 Zotac twin edge, 1 Zotac Tween edge OC and 1 EVGA 3060 XC.
Other less aggressive setting with the 2 OC, I obtain 107-108 MH when I use Core 0 Mem 550 PL100
Hello! 3060 lol miner
I have an issue of downgrading my driver to 460.39, After all I have done in my installation process for 460.39 and restart my rig, I am having a problem that my rig is offline, I did this for how many times, its the same result, my rig is offline, the solution is I need to Flash Again the image of HiveOS and go back to the Upgrade drivers which is working fine and I have the 36 MH…Anyone having the same issue on how to rich this higher 124.8 MH?
